configure ports ddmi
configure ports [port_list | all] ddmi [on | off]
Description
Enables or disables Digital Diagnostic Monitoring Interface (DDMI).
Syntax Description
port_list Designates the ports to enable or disable DDMI on.
all Designates enabling or disabling DDMI on all ports.
ddmi Designates enabling or disabling DDMI on specified ports.
on Specifies enabling DDMI on the selected ports (default).
off Specifies disabling DDMI on the selected ports.
Default
By default, DDMI is enabled.
Usage Guidelines
DDMI provides critical system information about the installed optical modules.
The following example disables DDMI on port 1:
# configure ports 1 ddmi off
This command was first available in ExtremeXOS 30.7.
Platform Availability
